How to convert shapefile to mbtiles and output file keeps input name?
  • Dec 14, 2020 5:16 AM UTC
  • 6 replies
  • 189 views
hoa_le
Hi all,
I am studying convert shapefile to .Mbtiles. But the output name I can't set as input file name.
I attacted my workspace in the below.
Could you tell me how to make output file the same input file?
Thank you
caracadrian
Forum|alt.badge.img+23
  • Dec 14, 2020 7:33 AM UTC
Use am AttributeCreator to put fme_basename in a "FileName" attribute, in the MapnickRasterizer set the GroupBy Parameter to the FileName attribute you created earlier, then set your writer Raster File Name parameter to the same attribute.
The only way to pass an attribute through the MapnickRasterizer is to use GroupBy
hoa_le
  • Dec 14, 2020 8:05 AM UTC
Thank you so much @caracadrian​ .
I want to ask a bit, can I style 2 condition in mapnickRasterizer. It means I want format based on attribute "reclass" in my workspace. How can I do?
caracadrian
  • Dec 14, 2020 8:28 AM UTC
Add it to GroupBy
hoa_le
  • Dec 14, 2020 8:54 AM UTC
Thank you so much :)
hoa_le
  • Dec 15, 2020 8:01 AM UTC
Hi @caracadrian​
When I export to .Mbtiles, I feel the resolution is not good. May be the cause is my settings.
Could you tell me how to make high resolution? Thank you
modelFME_tileMill
caracadrian
  • Dec 15, 2020 10:24 AM UTC
Hi @caracadrian​
modelFME_tileMill
@hoa_le​  play with the Cell Spacing parameter on MapnickRasterizer
Raster properties
