How to authenticate Esri ArcGIS Online (AGOL) Map Service via SSO
  • November 8, 2023
  • 90 views
Hi, I'm trying to create a connection with my enterprise ESRI account, but only have the option to enter a username and password, when I can only connect to this account via SSO. Any idea how to work around this? I have set up a web connection to my ESRI account but it doesn't automatically connect to the map service through this.image
Best answer by nielsgerrits
What version FME do you use? From 2022 you can use web connections to do this.
nielsgerrits
Forum|alt.badge.img+64
  • November 8, 2023
  • November 8, 2023
Ah I'm using 2021.2, thanks I'll have a look at upgrading!
nielsgerrits
Personally, I would prefer to be able just adding esri web maps, as a world basemap is accessible without the need of an agol account. But it does work.
