How I can retrieve the CURRENT TOKEN via REST ?
  • Apr 19, 2016 3:39 PM UTC
  • 110 views
simonstefan
patrick_koning
Forum|alt.badge.img+7
Something like this i believe.
FMEserver.generateToken( user, password, count, unit, callback) ,return String
see also
http://playground.fmeserver.com/getting-started/au...
simonstefan
  • Apr 21, 2016 12:51 PM UTC
see also
Thank you for your answer.
What I need is to get the current token, not to generate a new one and use in other applications configuration files, applications which will use the token to deal with the FME server.
It is possible to find a workaround but it is much simpler for Jenkins to get the current token from the FME server and automatically configure and deploy the rest of applications.
If I generate a new token, other machines will be able to use the old token?
Thanks,
  • Apr 21, 2016 2:26 PM UTC
Hi
can use the lookupToken() method:
FMEServer.lookupToken( user, password, callback ) , return Object
See also the documentation here.
David
patrick_koning
Thanks,
@simonstefan When a token for that user is already given out and still active you will be given back the same token. So it schould be the current one for that user.
