How download file in resources path using rest api
I try download file in resources path using rest api, using get method:
http://myhost/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/geodados/Bairro_Popular.zip?fmetoken=2c537eb21c3ff7b5e0d64be0d6a02b10f149a5b5
but my response is:
"message":"null for uri: http://myhost/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/geodados/Bairro_Popular.zip?fmetoken=2c537eb21c3ff7b5e0d64be0d6a02b10f149a5b5"}
My file is in Resources > Data geodados > Bairro_Popular.zip
My user has permissions.
Does anyone know the reason for the error?
Best answer by david_r
I do it using the following API endpoint:
http://<host>/fmerest/v3/resources/connections/<resource>/filesys/<filename>
Notice the "filesys" part between the resource name and the filename. And I'm also using the following headers:
Authorization: fmetoken token=...
Accept: application/octet-stream
Note that I do not put the token in the URL.
  • January 8, 2019
itay
Forum|alt.badge.img+17
  • January 8, 2019
Hi @tiagocnorberto,
The REST API training manual is a good place to start with FME Server REST.
Hope this helps,
Itay
  • January 8, 2019
More details in the API documentation: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/#!/resources/download_get_9
danilo_fme
Forum|alt.badge.img+45
  • January 8, 2019
Hi @tiagocnorberto
I agree with @itay and @david_r.
The API documentation and the REST API training manual are very interesting to help in this case.
Please, tell us the solution or not your Question.
Thanks,
Danilo
In my url, was missing "filesys". Now is working!! Thank you!!
My correct url is:
Using get method:
http://myserver/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/geodados/Bairro_Popular.zip?fmetoken=mytoken
Using post
Headers:
  1. Authorization: fmetoken token=...
  2. Accept: application/octet-stream
My file it's at : Resources > Data > geodados > Bairro_Popular.zip
Thanks,
