How can I access data that I have uploaded or written to my FME Cloud instance with my local machine?
  • Nov 29, 2016 1:59 AM UTC
  • 106 views
Small datasets uploaded or written to a FME Cloud instance can be accessed and downloaded via the FME Server WebUI of the instance.
For larger datasets and entire folders the FME Server REST API can be used.
I attached a workspace that uses the FME Server REST API to download the files and folders from the FME Server resources to a local machine.
fmeresourcedownloader.fmw
fmelizard
Forum|alt.badge.img+22
  • Dec 19, 2016 1:06 AM UTC
And in FME 2017 you can use the Select File From Web dropdown menu item when you're adding a reader and specifying the dataset, and select FME Server from there to use such files transparently within FME workflows. Available in both the data inspector and workbench.
salvaleonrp
Forum|alt.badge.img+23
  • Jan 2, 2019 7:05 PM UTC
The FMEServerResourceConnector worked for me downloading an fgdb stored on a subfolder under Shared Resource\\Data on an FME Server 2018.x Cloud instance.
