Hello, I have using FME server 2019.X and my workbenches were working fine with no issue. yesterday I was trying run a WB then I got the error in the attached image. anyone can help me in this
  • Oct 2, 2020 4:05 PM UTC
  • 62 views
gisuser
Participant
Forum|alt.badge.img+4
The WB reading fgdb from UNC path , I tried to read from local machine same error, read different data same error .
jovitaatsafe
Forum|alt.badge.img+11
Hi @gisuser​,
Are you reading from a zip file by chance? Would you be able to try enabling long file path names on Windows and see if that improves anything? Off the top of my head I am thinking about this article which provides some more information on errors reading zip files but I'm not too clear if that may be your case.
gisuser
Participant
  • Participant
  • Oct 3, 2020 2:24 PM UTC
Hi @gisuser​,
Thank u for your reply @jovitaatsafe​ ,
Actually I am facing the issue with the zip files and unzipped files .
I have tried to read data from my local system regarding the number of characters the same error .
my concern is the WB was working fine with no issue and we are reading the data from the same path , suddenly we start facing this issue from 2 days ago.
  • Oct 5, 2020 7:12 AM UTC
Concerning reading from a UNC path: is the FME Server service acount already configured for network access?
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_System_Services_Under_Different_Accounts.htm
gisuser
Participant
  • Participant
  • Oct 5, 2020 8:03 AM UTC
Hi @david_r​
Yes it is configured to read for network access, and it was working the day before with no issues.
Actually I checked the shared folder also it shared for everyone and there are no limitations to access it .
I ran one from the sample workbenches, it run successfully.
the issue is with the our Workbenches.
