Hello, Can somebody help me to call the following curl command through HTTPCaller via FME Desktop?
  • Nov 3, 2022 7:12 PM UTC
  • 5 replies
  • 272 views
$ curl -X POST --noproxy “*” -k "https://server_name/connect/token" -H "Content-Type: application/x-www-form-urlencoded" -d "username=asdfg" -d "password=ghjkl" -d "client_id=CLIENT_ID" -d "client_secret=CLIENT_SECRET" -d "scopes=openid profile role" -d "grant_type=password"
geomancer
Forum|alt.badge.img+71
  • Nov 4, 2022 7:25 AM UTC
Curl is meant to be run from the command line, not through HTTPCaller.
The SystemCaller may be of help here.
f.kemminje
Forum|alt.badge.img+11
  • Nov 4, 2022 12:55 PM UTC
you can use python caller also to do this
import urllib2
data = '{"nw_src": "10.0.0.1/32", "nw_dst": "10.0.0.2/32", "nw_proto": "ICMP", "actions": "ALLOW", "priority": "10"}'
url = 'http://localhost:8080/firewall/rules/0000000000000001'
req = urllib2.Request(url, data, {'Content-Type': 'application/json'})
f = urllib2.urlopen(req)
for x in f:
print(x)
f.close()
  • Nov 4, 2022 12:58 PM UTC
import urllib2
for x in f:
print(x)
f.close()
Thank you. I will try this
nampreetatsafe
Forum|alt.badge.img+14
Hi @sal​, check out this article which runs through how you might use the HTTPCaller to make a call using cURL: https://community.safe.com/s/article/Web-Services-cURL-and-the-HTTPCaller
  • Nov 7, 2022 5:11 PM UTC
Thank you. It is really helpful.
