FTP Caller causes URL using bad/illegal format or missing URL
  • Sep 15, 2016 8:56 PM UTC
  • 5 replies
  • 406 views
FTP Caller causes URL using bad/illegal format or missing URL. I am trying to upload a file to my ftp server but keep getting this error. Attached are the screen shots of my configurations. I have tried various different possibilities but no luck. I have no trouble uploading file to my ftp server through command line. Here is the
Variations I have tried (It can connect but says the url is bad! Because if i put bad username password etc I just get can't connect or get bad domain name error):
ftp://dev-gismap02.flysfo.com/
ftp://dev-gismap02.flysfo.com/home/abhandari/
ftp://x.x.x.x/
ftp://x.x.x.x/home/abhandari/
  • Sep 16, 2016 7:19 AM UTC
You have to put the complete filename in the URL, e.g.
ftp://dev-gismap02.flysfo.com/home/abhandari/testing.kmz
  • Sep 16, 2016 9:34 PM UTC
OK When I tried that, I get
2016-09-16 14:16:16|   0.2|  0.0|ERROR |HTTP/FTP transfer error: 'Couldn't connect to server'
Cannnot connect. I can connect fine via my shell for mac.
mark2atsafe
Forum|alt.badge.img+59
The full filename is definitely the way to go (I see other confirmation of that).
So if you are still having problems...
1) Try turning on Debug logging (Tools > FME Options > Translation > Log Debug) and see if that reveals any more information in the log window
2) Try writing to a site that I know works. Copy a small test file to ftp.safe.com/incoming/filename.kmz - no username or password required. I just did that and you can see that there is imarktest.kmz there. So I know it works for me. Let's see if it works for you. It will at least narrow down where the problem lies.
  • Sep 19, 2016 5:05 PM UTC
That worked for me.. I am not sure why its not working for my machine then. I can transfer file through my command line shell. I also made sure the username password is correct. I am using vsftd in redhat. Could it be having to put username and password?
This is the output for log file. ftp.txt (Is this the one you are looking for?)
  • Sep 19, 2016 5:22 PM UTC
Also configured anon login. Even that doesn't work. When I put the wrong dir I get access denied, which is good. But when i put the right dir, I get Can't Connect.
