FMEObjects API and Java7
  • Apr 3, 2013 3:36 PM UTC
  • 43 views
We are in the process of porting our Java FME Objects API based application from Solaris to Windows Server. In a Windows Server (2008 R2) environment, what is the latest version of Java7 that the FMEObjects Java API can be used with?
Cheers,
James Crone
fmelizard
Forum|alt.badge.img+22
  • Apr 3, 2013 5:47 PM UTC
If you have FME installed can can check the following locations (see point 6), otherwise since you are mitigating from Solaris (see Note on FME for Solaris or AIX) , contacting safe is advisable.
Hope this helps.
Thanks for the reply. Got an answer from support so all is well.
