FME Server - Arcpy
  • December 1, 2014
  • 21 views
sigtill
Forum|alt.badge.img+24
What is the minimum needed files to be able to run Arcpy on FME Server. It should be possible to only copy the related python-files and libraries and not the complete ESRI-stack. Also after looking at this: http://fmepedia.safe.com/articles/How_To/Choosing-a-different-Python-Interpreter-installation  it would be very nice to define the python-interpretor in the workspace ithself ie: FME_SERVER_PYTHON = c:\\ARcGISpython\\ to make it ieaser to move between python interpretors and from desktop to server
Best answer by david_r
you will need an installation of ArcGIS Desktop or ArcGIS Engine, as well as a license for this.
David
  • December 1, 2014
David
