FME desktop/server 2012 to 2013 Migration/compatibility
  • June 7, 2013
  • 6 views
Hi ,
Tried running few workbenches in built in desktop 2012 built on 2013 had macro issues hence translation failure.Had few question regarding interoperability and compatibility of desktops and servers.
1.Is there a tool/way to migrate a 2012 workbench to 2013 ?
2.If we use a 2013 fme server would that seamlessly support 2012 workbenches?
3.Eager to implement transaction support for oracle spatial ,is there a suite for the same in desktop 2012 ?
Best answer by david_r
the FME engine that is used on the Server and Desktop editions are exactly the same (given the exact same versions installed), and should work exactly the same way.
For most upgrades, it should be enough to just open the workspace in the upgraded version of FME, and it should run just fine. However, if you have used some advanced functionality, such a Python/TCL scripting, you might need to adapt the workspace / scripts slightly, depending on a lot of factors. Which error message did you get for your macro issue?
Not sure if I understand your 3rd question, could you perhaps elaborate a little? The Oracle Spatial Object reader and writer has had transaction support since at least FME2009, as far as I can tell.
David
  • June 8, 2013
David
