Hello,
as it says in the title: FeatureReader crashes on reading ArcGIS Pro filegeodatabase.
For my work I built a workbench were previously data got written to an Arcmap *.gdb which worked flawless. But now since my company is switching to ArcGIS Pro, I'm had to update the *.gdb to the ArcGIS Pro standards to be able to work with annotations. After running it with that updated *.gdb I received errors. After some fiddling it seemed that the issue was resolved. But a few runs later I found out that there were some attributes that I had to alter to the *.gdb to streamline it for later production steps. No probs so far. After doing that, the FeatureReader i use came up with the old attributes, and not the newly inserted. So I thought, I'll repoint it to the *.gdb, after doing so, the workbench crashed…
I've tried different things to find out where the problem lies: Maybe a feature had bad geometry? Maybe to many features? Maybe the *.gdb was corrupted? But nothing I did helped. As a last step I tried to create a new *.gdb in ArcGIS Pro and than try to load it with the FeatureReader… Also instant crash. Oh yeah, the created *.gdb was empty.
Log file shows nothing abnormal, the workbench crashes before it can write something.
The versions of software used are:
FME: FME(R) 2022.2.0.0 (20221103 - Build 22765 - WIN64) (and using FME python 3.10+)
ArcGIS Pro: ArcGIS Pro 3.1.2
I became aware of the workspace parameter Esri ArcGIS Compatibility setting in the Navigator where you can choose between auto/ESRI Arcmap/ESRI ArcGIS PRO, but unfortunately either setting won't fix the crashing.
Hello @cfdune, thanks for posting and sorry for not reaching out sooner. This doesn’t sound quite right, and I wouldn’t expect this process to cause a crash. Are you able to submit a support case with us, so we can take a closer look at the issue? Happy to help, Kailin.
At my company we work in VDI's and our department has several slightly different VDI's for different jobs. A fellow worker tried it on another VDI than our usual VDI and there it seems to work. So it is probably something underwater what causes this.
Please update to a more recent version of FME. It should be FME 2023.2 or higher. See the notes on FME and Esri versions:
https://support.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
After extensive searching, this reaction sums it all up.
The difficulty at my company was that our IT department upgraded ArcGIS Pro to a higher version, but didn't install the compatible version of FME next to it on my primary VDI. And like I said earlier, we work with different VDI's, so that makes it a little bit more complex to update, because of the different things we do here, we sometimes need newer or lower versions of software.  I was in luck that another department was running a lower version of FME with compatible ArcGIS Pro version.
IT has now scheduled to upgrade FME and ArcGIS Pro within a few weeks, and we are to test it first at a dev VDI.
@stalknecht You would know it, because you told me in person 😎
This combination crash FME Workbench when trying to open Feature types to read
  • FME(R) 2024.1.0.0 (20240628 - Build 24612 - WIN64)
  • ArcGis Pro 3.3.1
I have an Cloned Python env of my ArcGis pro install.
This is latest versions at current date as far as I recall.
R
