Esri feature dataset
  • Nov 19, 2012 5:36 AM UTC
  • 112 views
I am new to FME. I would like to convert the shape file / CAD file to file GDB / Personal GDB with Feature Dataset. how do I create Feature dataset using FME?
fmelizard
Forum|alt.badge.img+22
  • Nov 19, 2012 7:16 AM UTC
Hi
In feature type properties of the GDB writer ( format parameters tab) you can specify a feature dataset, FME will create the feature dataset and feature class belonging to it.
Regards,
Itay
thomas_g
Forum|alt.badge.img+13
  • Nov 19, 2012 8:56 AM UTC
If you want to write into a specific table (Feature Type), you can add the GDB-Writer first and chosing "No" when asking if you want to add a new Feature Type. After that you go to the point "Writers" in the menu bar and chose "Import feature types...". Finally when clicking the "Parameters"-Button you will see the field "Table list" where you can find the table you want to write in.
cheers,
Thomas
  • Jun 12, 2013 10:21 AM UTC
Hello
I didn't discover how to create feature dataset in FME 2013 since some settings are different. Can you help me with that?
Thank you!
Aliz
arnold_bijlsma
Forum|alt.badge.img+16
(Although already 4 years old, I had the same question and couldn't find the answer easily)
@etls_itay answered it pretty much, but he didn't mention you must create a GDB ArcObjects writer, as it won't work with a GDB API one. Then in the writer go to Properties > Format Parameters where you will find a box to set the Feature Dataset name:
