Esri ArcGIS Server Feature Service
  • Aug 30, 2024 7:04 AM UTC
  • 104 views
losanca
A month ago, I generated an fmw (Build 24202) that read from Esri ArcGIS Server Feature Service, (url, user, pwd) correctly.
today when opening the fmw gives error and is not able to read, I do not know why it can be, if everything is the same as a month ago.
Thank you so much!
hkingsbury
Forum|alt.badge.img+73
  • Sep 2, 2024 1:26 AM UTC
Are you using a web connection to provide authentication with the credentials? You may need to just re-authenticate the connection
losanca
  • Sep 7, 2024 6:24 AM UTC
thanks hkingsbury!
I can’t connect because of insufficient permissions
hkingsbury
  • Sep 9, 2024 9:40 PM UTC
thanks hkingsbury!
So you are using a web connection? Has the error being returned is one from arcgis so that suggests the username/password combination is not correct
