Email Notification and Feature Layer on AGOL
  • Feb 13, 2024 7:47 PM UTC
  • 304 views
hyperx
Forum|alt.badge.img+3
Is there a way to setup a trigger in FME to send an email anytime a new record is added to the Feature Layer. I have an AGOL hosted Public Facing Application where the residents can add points and fill out some information. I would like to get an email every time a new record is added by the user.
nielsgerrits
Forum|alt.badge.img+67
I think you can set up a webhook in AGOL on the feature layer, and point that to server.
nielsgerrits
Setting up an FME Server automation to receive webhooks:
https://docs.safe.com/fme/html/FME-Flow/WebUI/Automations-Triggers/Trigger-Webhook.htm
There is a different way to set this up, but I believe using automations is the current standard.
Setting up a hosted feature service webhook to submit when a change is made.
https://www.esri.com/arcgis-blog/products/arcgis-online/sharing-collaboration/how-to-create-a-hosted-feature-service-webhook/
