Doens't show the values in python
  • May 26, 2017 8:49 PM UTC
  • 39 views
danilo_fme
Forum|alt.badge.img+58
Hi users,
I have a script that create a route between two points ( start and end ) using library googlemaps.
The return is going well to attribute in format JSON.
The idea is extract the route information in 'html_instructions'. In PyCharm is work when i execute it:
I configured my Workspace and execute ( attached template file), but it brings only the last route between two points.
How can i get inside my Workspace all route and turn a attribute? Attached the JSON generated by request googlemaps and Workspace.
Thanks in Advance,
Best answer by geosander
Live from my gate at Vancouver airport..! 🙂
The more "FME way" to do it, is to not use a PythonCaller at all, but an HTTPCaller, I guess. That will return a JSON response, from which you can extract the instructions using a JSONExtractor, for instance.
However, if you do want to use the PythonCaller, please have a look at the attached workspace. The trick is to write to a list attribute. You can concatenate the instruction strings afterwards using a ListConcatenator if you want.
geosander
Forum|alt.badge.img+7
  • May 26, 2017 11:13 PM UTC
danilo_fme
  • May 27, 2017 1:13 AM UTC
Hello @sander_s , thanks your time when you wait your flight :)
Yes, i want to solve this with the transformer PythonCaller and your Workspace was perfect to resolve this. Thanks
I wish that you will have a excellent return your home.
