Direction using Python
  • May 31, 2017 2:54 PM UTC
  • 5 replies
  • 125 views
danilo_fme
Forum|alt.badge.img+58
Hello Team,
I want to extract a direction of driving between address points using the API from gogglemaps.
First i have the Origin Point and i need to find the next address ( point b for example ) from xls file. After from the point B find the next address ( point C ) and repeat this process 10 times.
I believe the best way to do this is a loop in python. Attached my template file.Thanks in Advance,Danilo
Best answer by carsonlam
Instead of making directions requests from A to B, then B to C, then C to D, etc., consider using the Waypoints feature in the Google Maps Directions API: https://developers.google.com/maps/documentation/directions/intro#Waypoints. That API allows up to 23 waypoints in a single Directions request.
carsonlam
Forum|alt.badge.img+7
  • May 31, 2017 6:33 PM UTC
danilo_fme
  • May 31, 2017 6:59 PM UTC
Hello @carsonlam, thanks your reply.
So the URL needs to put the end address first, and after the Waypoints. In my case the problem is when i read a xls file with address and needs to generate the route ( 20 points ) i doent know the end address.
Thanks Danilo
jdh
Forum|alt.badge.img+41
  • May 31, 2017 7:55 PM UTC
Thanks Danilo
Presumably the end address is the last line of the excel file, ie the feature with the max value of xlsx_row_id.
carsonlam
  • May 31, 2017 8:44 PM UTC
Thanks Danilo
The order of the URL arguments should not matter. You should be able to build up a URL with parameters like
?origin=Surrey,BC&waypoints;=Coquitlam,BC|Burnaby,BC&destination;=Vancouver,BC
danilo_fme
  • May 31, 2017 9:04 PM UTC
Thanks all your help. :)
I updated my template file and it brings in JSON attribute the point next to point A ( start ) = Valor{2}.
Now in Loop i need to get this point B and search the next address ( others two attributes from xls file Rua Cedral,366,Jardim Satelite, Sao Jose dos Campos and Avenida Doutor Joao Batista Souza Soares,300, Jardim America,Sao Jose dos Campos )
Thanks in Advance,
workspace-api-google-maps.fmwt
