Default background Map Authentication - Connection failed
  • Jul 24, 2024 1:31 PM UTC
  • 384 views
bpoffet
When i try to “inspect feature caches” or “view sources data” it does not work and i get this error message :
I am not able to use any defaut background map. When I click on “OK” then the software crash.
Any suggestions ?
Best answer by raymondbrunner
Thank you, @bpoffet !
I was able to resolve this issue two ways, and one of them was by configuring a Web Service and adding a background map definition in the FME Options as you suggested.
The first method was quite simple, but might not apply to all users. By going into the Network Proxy settings I selected “Use system proxy settings” and the Default Light, Dark, and Terrain backgrounds started functioning.
The second method was more involved and comprised of:
  1. Creating an app in our enterprise ArcGIS Portal web service in order to generate a:
    1. Client ID
    2. Client Secret
  2. Creating a Web Service in FME Workbench Form Options based on the Esri ArcGIS Portal (Template)
    1. Being sure to “TEST” the configuration before closing the configuration
  3. Creating a Web Connection in using the Web Service defined in the previous step
  4. Adding a Background Map definition using the Web Connection
    1. Repeat for other Background Maps if desired
crystalatsafe
Forum|alt.badge.img+32
Hi @bpoffet
Which version of FME are you using and what is the background map you have?
I’m not sure if this could be related to the Stamen Background Maps Deprecation.
Do you also receive an error message in the graphics view?
raymondbrunner
Forum|alt.badge.img+11
I have two installations of FME Form (v2023.2 b23774 & v2024.0 b24202) on my workstation and both builds began experiencing the same issue yesterday.
Even if I create a simple workspace, with only a single Reader for an Excel spreadsheet, with no spatial component and nothing geographic to display.
After running the workspace with Feature Caching enabled the magnifying glass, or eyeball icon, will turn green, but will not display any records.  After about ten minutes the “Default Background Map Authentication” warning will appear.
We have other similarly configured workstations on the same network, and they are not affected.  There is something with this one workstation, and it affects both installations of FME Form Workbench.
bpoffet
  • Aug 21, 2024 6:45 AM UTC
Hi @raymondbrunner,
What solved this problem for me was to add a background map in FME Options. To do it I had to add also a new connection in “Network Proxy” in FME Options (maybe this is only because of my personal configuration). Personnaly I added the WMS.GEO.ADMIN backgroundmap and it worked.
If you don’t have already done it maybe give it a try !
raymondbrunner
  • Aug 21, 2024 1:34 PM UTC
    1. Client ID
    2. Client Secret
