Create new subscription with REST API
  • Jan 20, 2014 6:21 AM UTC
  • 42 views
Hi
Im looking for a way to automatically post a new subscription, preferably in a python startup script. Is it possible to use the REST API for this task?
  • Jan 20, 2014 8:49 AM UTC
that should be possible using FME 2014 and the latest version of the REST API. I'm not sure if it's possible with FME 2013 or earlier.
Start here for more info.
David
  • Jan 20, 2014 8:58 AM UTC
Ah thanks, that sounds good. Still running 2013 here, will hopefully upgrade soon!
Strange though I cant get to see the documentation:
FME REST Service Error: java.io.FileNotFoundException: apidoc
  • Jan 20, 2014 9:25 AM UTC
the URL that is in the posted link will only work for FME 2014. Version 2 of the REST API isn't available in earlier versions.
For FME 2013, try this URL instead:
http://<host>:<port>/fmerest/
If that doesn't work, look at the documentation in the FME Server installation directory.
David
