Could not connect to FME Core after running a failover test
  • Nov 29, 2017 6:02 AM UTC
  • 36 views
rob_datavision
I have set up a active passive architecture as per the guide
https://docs.safe.com/fme/2016.1/html/FME_Server_Documentation/Content/AdminGuide/Active-Passive-Basic-Architecture.htm
Everything on the system runs as expected - no problems for a couple of weeks since installation.
I then run a failover test as per the guide
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Test_for_Failover.htm
After that I can no longer access FME core even the the logs say it is running. I have checked everything but despite all my efforts, I cannot connect to the core via the web app server.
Has anyone had this problem? Can anyone provide some guidance on how to fix this please?
rob_datavision
I just solved my own problem. I reviewed all setup steps - particularly the configuration file settings. I misread one word.
On this page https://docs.safe.com/fme/2016.1/html/FME_Server_Documentation/Content/AdminGuide/Install_the_FME_Server_Services.htm
Under the heading Configure the FME Server Services for Failover it says
  1. Open each web application properties file located at:
<WebAppDir>\\<fmeServiceName>\\WEB-INF\\conf\\propertiesFile.properties
Initially I found one file and changed that. I didn't realize there were more!
I just did a search on files with name propertiesFile.properties in the installation folder and found 9!
6 needed to be updated. 1 had been updated and 2 did not have the setting.
I made the changes in ALL the files, restarted the service and everything was back to normal.
The failover test then succeeded.
What a relief. Big impact from a simple mistake.
Perhaps in Australia we are divided by a common language. I might have worded it "Open all web application property files located at". I might also have listed the possible <fmeSrviceName> folders to make it clearer.
