Converting from .NWD to .GDB
  • May 23, 2025 4:02 PM UTC
  • 288 views
snh_1_fme
Participant
I am having some issues converting a .NVD to .GDB to display in ArcGIS Pro. I can get the attributes all across but cannot view the geometry in FME
Does anyone have any guidance on how to transform the geometry so it displays in a geodatabase in ArcGIS Pro?
Thanks
raghavendrans
Forum|alt.badge.img+28
​@snh_1_fme
You will need to share some more information on the type of data in your Navisworks distribution file (nwd) and what kind of geodatabase is it?
Are the feature classes with the geometries already defined in the geodatabase for ready use or FME needs to create the geodatabase from scratch?
SRG
snh_1_fme
Participant
  • Participant
  • May 24, 2025 10:12 AM UTC
Thanks for responding ​@raghavendrans
Am fairly new to .nwd file type but the model is split across 15 or so disciplines with vertical structure. Most objects are just 3D solids. I am creating a new geodatabase so that is completely flexible
Let me know if you need more specifics
evieatsafe
  • May 27, 2025 5:18 PM UTC
Hi ​@snh_1_fme thanks for your question. Glad to hear that you want to integrate your Navisworks with FME. Sounds like your data is 3D with various types. A geodatabase has some restrictions on geometry types that it supports, so you may want to check our documentation and your data to see what FME detects your data as. If the GDB doesn’t support that geometry you can transform the data into a compatible geometry before writing to the GDB in FME.
Are you able to inspect the data in FME Data Inspector or within Workbench in the Visual Preview? If so, going to the Feature Information Window will let you know what geometry it is.
What error are you getting right now? What does it look like in ArcGIS when you try to open it?
bzagd10
Participant
  • Participant
  • Nov 10, 2026 8:05 AM UTC
​@evieatsafe Is there any roadmap for supporting Navisworks formats (NWD, NWC, and NWF) directly in ArcGIS Data Interoperability?
