Connection to Microsoft Graph API
  • August 15, 2018
  • 8 replies
  • 476 views
sigtill
Forum|alt.badge.img+25
Have anyone managed to connect to Microsoft Graph API? I am thinking about the authentication part
https://developer.microsoft.com/en-us/graph
The authentication is described here: https://developer.microsoft.com/en-us/graph/docs/concepts/auth_overview
Any help?
Best answer by gerhardatsafe
@sigtill
I uploaded a Microsoft Graph Web Connection to the FME Hub:
https://hub.safe.com/web_connections/microsoft-graph
You will need to create an app here to use the Web Connection: https://apps.dev.microsoft.com/
Once you add your client ID and client secret you can use the Web Connection as authentication in the HTTPCaller.
@sigtill
sigtill
  • August 21, 2018
@sigtill
Spot on Gerhard! I always forget the web-connections. And I havent used it a lot. I am guessing its also possible to create a similar web-connection towards Leica Conx (https://knowledge.safe.com/questions/65547/data-tofrom-leica-conx.html) - I will have a dive into that when there is some spare-time!
sigtill
  • September 5, 2018
@sigtill
It seems the token times out after 1 hour and I need to sign in again - is there an error in the refresh-token string? @GerhardAtSafe
sigtill
  • September 5, 2018
@sigtill
I also added a comment regarding changing scope: https://hub.safe.com/web_connections/microsoft-graph
NB! Remember to change the scope to suit what you need access to: for instance mail.read or calendars.read etc. If not - it will not work. And documentation is available here: https://developer.microsoft.com/en-us/graph/docs/api-reference/beta/beta-overview
It's a good point, I'll add this to the description.
There could be 2 reasons for this:
1. The redirect URI is missing in the refresh token request. We add it automatically to the retrieve token request, but not to the refresh request. You can try to add it as a query string to the token request. This is the example I followed by the way:
https://docs.microsoft.com/en-us/azure/active-directory/develop/v2-oauth2-auth-code-flow
2. You might need to grant the offline_access scope for your app the successfully retrieve refresh tokens:
https://docs.microsoft.com/en-us/azure/active-directory/develop/v2-id-and-access-tokens#refresh-tokens
Let me know if you get a chance to test these 2 options. I will update the Web Connection on the Hub as soon as get to it so if you can confirm a fix by then that would be really helpful.
Thanks!
Thanks!
You have to insert the "redirect_uri" as an URL, I tried with [REDIRECT_URI] at the Refresh Token Parameters - Request Format, but it didn't worked.
sigtill
  • September 11, 2018
@GerhardAtSafe - as @arnebrucksch says you need to add the redirect_uri as an URL.
