Connecting to the Yelp API
  • March 13, 2017
  • 11 views
Hi Folks,
I'm trying to connect to the Yelp Fusion API, I read the documentation and it appears to use a OAuth2 authentication. From reading up it should be possible to set this up in FME. Ideally I want to have a yelp connection I can use in conjunction with a HTTPCaller transformer in FME.
I tried numerous things but still getting a 404 error. Here's how my current connection looks:
All suggestions welcome
Best answer by itay
Hi @osarhan,
I think that for setting up the Web Service connection you can better ask support.
Next to that setting up the HTTPCaller to get the token is not that difficult, see image below.
Hope this helps.
itay
Forum|alt.badge.img+17
  • March 13, 2017
Hi @osarhan,
Hope this helps.
