Can we hard-code the timeout period on a Token Service web connection?
  • Nov 3, 2021 2:35 PM UTC
  • 72 views
We are using a custom Token Based web connection to an external service. The service does not return an expiry time - it is always 180 minutes.
Is there a way to hard code an expiry duration on a token retrieved by the web connection? The UI for defining a Token Based web connection seems to only support an expiry time being returned by the token service.
caracadrian
Forum|alt.badge.img+23
  • Nov 3, 2021 3:45 PM UTC
It depends on the service.
Can you provide a return example from a browser Developer Tools so we can see the Headers and the Response?
  • Nov 3, 2021 3:58 PM UTC
The response body is JSON:
    "success": true,
    "message": "Logged In",
    "data": {
        "token": "dc..redacted...aebea8b0192661"
There is a Date header in the response, which is the current time (of the web server).  No other notable response headers (just standard ones like content length, content type).
