Can FME ReST API calls be made between 2 computers in a network
I would like to create an FME workspace and publish it on one computer as a ReST API and would like to access that API from another computer in the same network.
Best answer by david_r
Yes, that is definitely possible, and I'd say it's a major reason for the REST API.
You just have to make sure that there is is no firewall or router blocking access over port 80 (or 443 if you're using SSL) between the two machines.
  • January 7, 2019
Thanks David.
Apologies as I am asking some basic questions. If I use my system to store FME workspaces, how do I use it to publish or make it available through REST API from another system on the same network ?
Thanks in advance.
  • January 7, 2019
bey_atkins2009 wrote:
Thanks David.
Thanks in advance.
Don't worry about asking questions, that's why we're here :-)
To get a feel for the REST API, I recommend that you look at the FME Server Playground, there are lots of documentation and examples to look at:
https://playground.fmeserver.com/
Feel free to come back and ask more questions.
tyricores
  • August 24, 2021
There are a lot of ways you can create an FME workspace. I found out about them on https://10roar.com/, and the article helped me out a lot. It's actually way easier than it seems. You'll first need to go into the file, then click generate workspace. You can also create a dialog. There are particular fields for the location and format of both the data to be read and the data to be written. There is a key requirement, though. I'm talking about the structure of the source data. All format selection fields let you type to search formats. Hope this helped!
