Background Maps fail to open
ev_robin
Forum|alt.badge.img+11
I could use some help figuring out how to get MapQuest maps loaded in FME. I get a python exception when I try to load any background maps other than a WMS in the preview window and Data Inspector.
Python Exception <ImportError>: bad magic number in 'requests.packages': b'\x03\xf3\r\n'
Could not create Python Reader `MAPQUEST_WMTS'
A fatal error has occurred. Check the logfile above for details
Failed to open the dataset ''
DATASET INFO:
    DATASET:
    NUMBER OF PARAMETERS: 2
        RETRIEVE_ALL_TABLE_NAMES = Yes
        _API_ACCESS_TOKEN = 3LjBtfAjxV6mr8nczRSuENeEtSk83gv7
I have an API key for MapQuest that was working in FME 2018, and I signed up for a new one in MapBox and found that I got the same error in FME 2019. I'm sure there is someone here a lot smarter than me who can figure this out, so thank you.
edit: I realize the problem is only using 64bit FME. I have a 32 bit version and a 64 bit version installed.
I had an error during the installation that said it couldn't shut down all the programs using a shared library (probably a python library, given the error).
Forum|alt.badge.img+50
Is the API key you used in FME 2018 still working?
And please forgive me for asking the obvious here... but you say you signed up for a new API key in MapBox, did you mean to write MapQuest?
ev_robin
  • May 7, 2019
Hi, thanks for the reply. The API key still works on other computers with FME 2019. I don't have 2018 still installed on my computer to test, because I installed 2019 in place of 2018. I did actually get a MapBox API key as well. Just now I realized the issue is only with the 64 bit version. The 32 bit version works fine, but I mostly use 64 bit FME.
chrisatsafe
  • May 7, 2019
Hi @bruttino,
Did installing 64-bit FME 2019.0 resolve the issue or are you still unable to load the background map in FME 2019.0? I just tested the MapQuest background map on my machine using 64-ibt FME 2019.0 and I wasn't able to get the same error.
If you are still experiencing issues, I would recommend contacting our support team by Submitting a Case and including the FME report by running the system_information.bat from the General Troubleshooting | Gathering System Information article.
ev_robin
  • May 7, 2019
chrisatsafe wrote:
Hi @bruttino,
Hi, I reinstalled FME 2019 and it worked! I should have tried that before. Anyways, thank you for your help! I remember getting a warning during installation of the 64 bit FME that it couldn't shut down all the programs the first time I installed.
chrisatsafe
  • May 7, 2019
Glad to hear! Thank you for following up @bruttino!
