autocad map 3d
  • May 2, 2024
  • 0 replies
  • 33 views
brinda
Observer
Hello please I need help. I converted my Autocad Map 3D files to integrate them into my database using the 'Raw relational' mode because my data has multiple tables and one entity with several attributes. Currently, I would like to convert them back into Autocad Map files while preserving the original file structure. I'm stuck because I can't recreate my different tables (Table A and Table B). What should I do?
