Attribute convertion
  • August 23, 2024
  • 94 views
louis_boekhoudt
I am in need to convert an attribute with “188-195” as value (Wich means 188
up to and including
195) in “188;189;190;191;192;193;194;195”.
How can this be done in FME workbench 2024.1.0.0.
With a  combination of transformers AttributeCreator, AtributeSplitter, ListElementCounter, ListExploder and AttributeManager I am be able to produce the 8 new features.
THNX.
Best answer by nielsgerrits
Multiple ways to do this.
Pure FME:
  • AttributeSplitter to split the values to a list.
  • ListExploder to create features from the list.
  • StatisticsCalculator to calculate the minimum value and the range.
  • Cloner to create a feature for each position in the range.
  • AttributeCreator to calculate the value for each feature using min value and copynum
  • Aggregator to merge all features and concatenate the string.
Python:
  • PythonCaller with
import fme
import fmeobjects
class FeatureProcessor(object):
    def input(self, feature: fmeobjects.FMEFeature):
        # Get the input from an attribute.
        input_string = feature.getAttribute('input')
        # Split the input string to get the start and end of the range.
        start, end = map(int, input_string.split('-'))
        # Generate the range and join with semicolons.
        output_string = ';'.join(str(i) for i in range(start, end + 1))
        # Write the result to an attribute.
        feature.setAttribute('output',output_string)
        self.pyoutput(feature)
Sample workspace attached.
nielsgerrits
Forum|alt.badge.img+64
  • August 23, 2024
Pure FME:
Python:
  • PythonCaller with
import fme
import fmeobjects
dustin
Forum|alt.badge.img+31
  • August 23, 2024
This should do the trick:
  • ExpressionEvaluator to get the numbers of digits
  • Cloner to create a feature for each digit
  • Another ExpressionEvaluator to add the cloner copy number to the first range number
  • Finally an Aggregator to combine all the values
bwn
Forum|alt.badge.img+26
  • August 25, 2024
Personally I would use a Cloner based solution similar to @dustin’s solution for ease of implementation and self-documentation, but a speedy alternative solution that uses less Transformers is to use SQL Recursion inside the SQLite based InlineQuerier
It is sort of in-between using just out-of-the-box Transformers and having to go full programmatic mode in Python (which can bring its own debugging issues)
SQL Statement in the sample InlineQuerier below is
WITH RECURSIVE
--Common-Table-Expression that extracts the Left and Right Numbers arounda "-" character
ValueRange(ID, MinNumber, MaxNumber) AS
SELECT
ID
,0+(trim(substr("test_attr",0,instr("test_attr","-")))) AS MinNumber
,0+(trim(substr("test_attr",instr("test_attr","-")+1))) AS MaxNumber
FROM "Output"
--CTE that initially selects a single row with the dervied Minimum and Maximum Numbers
--and then keeps attempting to add new rows with a List Value = to the Previous Row List Value + 1 until reach MaxNumber
--As safety mechanism to prevent infinite looping, hard code an upper trial limit of 10,000 new values
,ClonedValues(ID,MinNumber,MaxNumber,ElementID,ListValue) AS
SELECT ID, MinNumber, MaxNumber, 1, MinNumber FROM ValueRange
UNION ALL SELECT ID, MinNumber, MaxNumber, ElementID+1, ListValue+1 FROM ClonedValues WHERE ListValue<MaxNumber AND ElementID<10000
--Select all Values from the CTE--
SELECT * FROM ClonedValues
Input
Output
