Attempting to Configure API Json for FIrst Time
  • Aug 22, 2020 7:31 PM UTC
  • 96 views
Hi all,
I am trying to use the following link to setup a json file and automated script to extract data. It is the first time I have attempted to do this and I have used the httpcaller and also tried the json reader to get an output.
I am just trying to tackle this one step at a time and very eager to get my first API working. In terms of the link I used https://api.coronavirus.data.gov.uk/v1/data which I added to the httpcaller. It did pick this up and then i was not able to get anything from the attributexposer. Can anyone assist with what they would recommend as next steps?
Link to dev guide - https://coronavirus.data.gov.uk/developers-guide
Best answer by takashi
Hi @cardiofaz​ , I would use the JSONFragmenter to fragment the JSON document into features for each date and also convert the pairs of name and value to feature attributes.
Example:
jsonfragmenter-example
  • Aug 23, 2020 1:20 AM UTC
I have made some progress with this now and have got the URL to work:
I am getting the data in following output with name and newcases in the same row and column.
What would you recommend to have Column 1 - Name and Column 2 NewCases. Then for the outputs to generate into rows? Would a list be the best possible solution?
newcases
  • Aug 23, 2020 9:37 AM UTC
Example:
  • Aug 23, 2020 9:43 PM UTC
Example:
That is great, thanks for the suggestion for the httpcaller. That seems to have done the trick, much appreciated.
