API multiple records with limit
  • October 23, 2018
  • 179 views
ayraju
Hello
I am trying to download multiple records using HTTPCaller from a API endpoint. I need to get all records updated in last 7 days. I plan to schedule to run this on daily interval.I have used a query to get the max date and passing it to get recent data.
The issue is that the API only allows 1000 records at a time. One has to set an offset start at 0,1000,2000 etc to get additional records. I dont know the number of records updated until i query all of them 1000 at a time.
What is the best way to loop the Httpcaller and automate it so when i run it all records that were updated in last 7 days let's say it is 1800 are downloaded.
Unfortunately I cannot share the API details.
Best answer by jdh
Here is the outline of a custom transformer that loops through the api results. The httpCaller should have the _offset attribute in the url, rather than have a number hardcoded.
Note that regardless of the results of hasMore, the current result set is processed.
fetchloop.fmx
jdh
Forum|alt.badge.img+28
  • October 23, 2018
Does your api return a cursor, or nextPage, or even the total number of results, when you make the first query (offset =0)?
ayraju
  • October 23, 2018
No, it only shows a result "page":{"offset":0,"limit":1000,"hasmore":true}
I am thinking maybe i somehow parse out hasmore = true and then keep running the caller until is false. I just wasnt sure how to add a loop.
jdh
  • October 23, 2018
fetchloop.fmx
ayraju
  • October 23, 2018
fetchloop.fmx
Thank you, this is exactly what i needed.
