If you go into FME Options>Background Maps you can then add a new background map from a source. Entering any required information. Once added there is a drop down option in the Graphics Viewer where you can select from added background maps and add new ones. Similar process if you are using Data Inspector.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
