PythonCaller Failed 'FeatureProcessor' error with ArcPy
galigis
Forum|alt.badge.img+20
Hi All,
Quick question in regards FME & ArcPy: I have been able to create a Python script that overwrites a ‘tree_ID’ field on AGOL based on the sum count of the three geometries (point, line and polygon). Basically the script does the following calculation and assigns the IDs, example below:
Point = 3 features
Line = 2 features
Polygon = 2 features
TOTAL = 7 features
ID to update on AGOL 1,2,3,4,5,6 and 7
The python works fine as the AGOL feature hosted layers have been updated with the new ‘tree_ID’ but the PythonCaller stops with the following error: ‘PythonFactory failed to load python symbol `FeatureProcessor'. An outdated FME packaged transformer may be in use. Please check Tools > FME Options > FME Packages to confirm that all FME Packages are up to date’
I can always run it on Pro but wanted to integrate it using PythonCaller as part of my workflow runs on FME,
Any idea why I’m getting that error?
PD: Python script attached.
Best answer by nielsgerrits
I’m by no means a specialist in this field, but you will get this error as long as you do not put your code within the class “FeatureProcessor” as the sample is created when opening a new, default PythonCaller.
nielsgerrits
Forum|alt.badge.img+55
  • April 2, 2024
galigis
  • April 2, 2024
Thanks @nielsgerrits your guidance has helped a lot! Issue has been fixed now after adding the class “FeatureProcessor” and define ‘__init__’ and ‘input’.
I have attached the final Python codes for completeness in the case someone else faces the same issue in the future!
nielsgerrits
Cheers :)
