It would be handy to have the possibility to use parameter values in the Creator. For Example, now you have to combine the Creator with a 2DBoxReplacer to be able to use the parameters. Why not directly in the creator?
You can use parameters in a Creator if you choose geometry source 2D Min/Max Box if it's just a box you are after. Agree it would be useful if parameters were accessible in the Geometry Creator
