Released
Table parameter type
Related products:FME Form
  • September 18, 2025
  • 7 replies
  • 177 views
nordpil
Forum|alt.badge.img+12
There are times where I would like to store more complex data as a parameter, I have resorted to json or comma-separated text (multi-line text parameter). This is mostly private parameters that specify data source, configuration or possible some initial data. In nature this data is tabular, most of the time.
  • Maintaining json/text in a parameter dialog today is cludgy
  • Getting the data into features requires multiple transformers
Now, wouldn’t it be nice with a table parameter type? Using a parameterfetcher could possible read the table into a list, that one can just explode/expose. Maintaining the data in a dialog set for a table would also be easier… !
alexbiz
Forum|alt.badge.img+35
Hey ​@nordpil !
Have you taken a look at this?
It was added in 2025.1
jennaatsafe
Forum|alt.badge.img+5
In 2025.1, we added Tables as a new Parameter type. This allows you to create tables with up to 5 columns, configuring each column to a supported Type (e.g. Choice, Text). This idea will be moved to Released.
If anyone interacting with this new feature has ideas on how it could be improved, or is finding it does not support something they are trying to accomplish, we would love to hear the details in a new Idea.
jennaatsafe
New→Released
nordpil
  • September 19, 2025
Cool - I am still on 2022.2.8… !
crutledge
Forum|alt.badge.img+55
ooo. this is lovely!
Forum|alt.badge.img+54
I’m not sure what advantage the table parameter offers in its current configuration
When you fetch the parameter it’s just returned as a delimited string, so you still need to do a certain amount of manipulation to get into features.
Might as well just paste a csv as text in the first place.
btl
  • January 14, 2026
I suppose it gives a nice user interface for Flow Apps.
Unfortunately, for my first use case, the limit of 5 columns is too small - I really want 14.
