Open
Search for all places an attribute is modified or published parameter is used
Related products:FME Form
  • October 29, 2015
  • 14 replies
  • 173 views
fmelizard
Forum|alt.badge.img+21
Across all of workspace, not just current tab. Provide for easy navigation of the reference places. Allows for easy "tracing" of operations affecting an attribute or published parameter.
mark2atsafe
Forum|alt.badge.img+59
  • November 23, 2015
I'm told this is half-complete! Currently works for published parameters, not for attributes. Sorry, not sure if 2016.0 or 2016.1
flavien
  • October 30, 2020
I think a problem with the search is that it returns all AttributeManagers where the attribute appears, even if nothing is done to this attribute. It makes finding what happens to an attribute longer.
whkarto
Forum|alt.badge.img+14
  • May 1, 2023
What happened to this development? It's been quite a while since 2015 and still no such function has been published. Especially in huge workspaces this feature would help so much. I'm so fed up with crawling 20+ AttributeManagers until the one where an attribute has been set can be found.
Guys this can't be true by 2023! Please add a "Search declaration" option to the workspace search.
LizAtSafe
Forum|alt.badge.img+18
  • February 8, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
chriswilson
  • January 9, 2025
This could be expanded to include a find and replace for attribute values, e.g. in my case a variation to a URL that is used in multiple locations in the workspace.
  • January 10, 2025
My personal take is to recommend that static information like this should live in a private parameter, so that there’s only one place to modify it.
chriswilson
  • January 14, 2025
In the case I was thinking of the URL has a dynamic attribute value in the middle so that would need to be nested in the parameter, which it could be.  Sometimes however I think hiding everything in parameters and back-end value configurations etc. isn’t always the way to go, especially when sharing workspaces with less experienced FME professionals for whom it’s sometimes easier to see things laid out in the GUI.
In my own view having the same text in different parts of the workspace has its place, as does a find and replace, but you do have a point as well.
