When using a core dataset (that changes in time) which is used in diverse workflows/ workbenches, and when that core dataset is updated/ changed, it would be good to find all the workflows that contain that dataset and which derives many other outputs. This is so you can change or, check that the workflow is updated.
We use a core policing administrative boundary dataset (beat boundaries) which is linked to n number workflows... for example: to convert in various formats (for our different systems) or to calculate and output many other variables at beat level (e.g. demographics, etc.)
With more and more automated workflows running, I find it that I always end up forgetting to update at least one workflow.
The ability to search for which workflows in a folder / drive contain that particular data source (also using wildcards - e.g. *beat*.shp) then we would be able to go through the list and amend the workflow (or check it is running smoothly!)
Thank you!
