Open
PythonCaller gets python code from attribute
Related products:Transformers
siennaatsafe
hkingsbury
danilo_fme
tcrossman
+30
  • siennaatsafe
    siennaatsafe
  • david_r
  • hkingsbury
    hkingsbury
  • danilo_fme
    danilo_fme
  • tcrossman
    tcrossman
  • vxn43
    vxn43
  • mattwilkie
    mattwilkie
  • lorenrouth
    lorenrouth
  • jackyd
    jackyd
  • olivier
    olivier
  • thdrg
    thdrg
  • koenterralytics
    koenterralytics
  • revesz
    revesz
  • victors
  • iangr
    iangr
  • tijs
    tijs
  • lde
    lde
  • esietinga
    esietinga
  • cwarren
    cwarren
  • carlm
    carlm
  • par_smars
  • kd
  • samisnunu
    samisnunu
  • ekkischeffler
    ekkischeffler
  • lau
    lau
  • roland.martin
    roland.martin
  • stipica.pavicic
    stipica.pavicic
  • jeroen
    jeroen
  • jneujens
    jneujens
  • taojunabc
    taojunabc
  • jpvo
    jpvo
  • jeand
    jeand
  • justinemarechal
    justinemarechal
  • hendrikh
  • mairesse
    mairesse
jpvo
I'd like to be able to maintain python scripts as .py files independant from my workspace (Like I do with sql scripts and SQLExecutor). The pythonCaller doens't allow to parse python code from an existing fme attribute.
That would be handy to implement an AttributeFileReader to read from the .py file and a PythonCaller to run the python script from the _file_content attribute.
Advantage: proper version control of the python scripts in GIT
lau
Forum|alt.badge.img+3
  • November 24, 2017
... and add a rejected port?
jneujens
  • November 28, 2017
... and better debugging? :)
paalped
Forum|alt.badge.img+5
  • December 7, 2017
No problem, Here is a very simple non-safe example:
import fmeobjects # Template Class class FeatureCreator(object): def __init__(self): pass def input(self,feature): newFeature = fmeobjects.FMEFeature() with open('C:\\\\temp\\\\test.py','r') as pyf: for line in pyf.readlines(): if not line: break else: exec(line) self.pyoutput(newFeature) def close(self): # close method must be defined # # output features here to create the features # after reader features have been processed pass
And your c:\\temp\\test.py:
newFeature.addCoordinate(0,0,0) print 'new feature at 0,0,0'
davideagle
Forum|alt.badge.img+21
  • July 29, 2021
Just had exactly this request today. A prospect wanting to use FME to call GIT managed python code directly from the PythonCaller. The SQLExecutor has the ability to read SQL from an attribute so the same capability for the PythonCaller would be a starting position for this that would add some value.
tijs
Participant
  • Participant
  • November 23, 2022
To add to this proposed idea: support Python code that is managed by a git repository AND that runs within virtual environments that can’t interfere with any dependencies that FME has.
I wouldn't support the idea of including code in attributes, just a reference to the directory/file with the code. The workspace features could be stored in a temporary dataset rather than directly ported via the FME python library.
Ideally the log files of the FME job would also include all log output from the script.
LizAtSafe
Forum|alt.badge.img+15
  • February 8, 2024
The following idea has been merged into this idea:
jeand
All the votes have been transferred into this idea.
LizAtSafe
  • February 8, 2024
LizAtSafe
  • February 8, 2024
