Gathering Interest
Pass parameters to FME Server App via URL
Related products:FME Flow
Show first post
nathanatsafe
Forum|alt.badge.img+7
Hi all,
We're currently working on features related to this Idea such as allowing Flow App authors to configure pre-populated parameter defaults and choice options, including something like a “cascading choices” feature. I’m not sure we’ll capture all the use cases listed in the comments here with this iteration, but I think what we’re building will enable the spirit of the OPs scenario, and perhaps more.
If you'd be interested in testing these features upon their beta release, please contact me at nathan.hildebrand@safe.com for further details.
Thank you for your continued support and engagement with this Idea and in our community at large!
janrykr
  • June 18, 2024
@nathanatsafe
I second others on the need for this function. This is a needed functionality, commonly known as Deep linking - Wikipedia
Use case:
  1. Access a feature on a ESRI based webmap (ether WAB or ExB). The layer has a dynamic field configured using arcade. The field essentially creates URL with parameters to be passed to FME Server App. The field will be exposed as a hyperlink in a pop-up or attribute table).
  2. Once a user clicks the hyperlink, they will be directed to the FME App with the parameters populated with the feature attributes. The app can be also built-in into an Experience Builder page. The parameters can even remain hidden in the app interface and the uer will be only prompted with “Do you want to update this feature?” and a button to trigger the job.
  3. The user only needs to click OK to trigger the process without modifying any parameters.
This will address following problems:
  • Make an edit that is not possible within the webmap environment. For Example:
    • Make this feature exactly 5x larger.
    • Update values based on intersection with another layer after a feature was moved.
    • Recalculate coordinates after a feature was moved.
  • Generate a report for the feature.
  • Faster processing by filtering data processed in translation as FME will only process one feature (or limited number of features).
Hardcoding values into user parameters into server app will not work in this scenario, since we only want FME to work with the feature selected in the map and with its attributes.
I am aware this can be achieved via the FME API, but this function will offer simpler development.
abelisle
Participant
  • Participant
  • June 21, 2024
Hi @nathanatsafe ,
For example, I have my FME app that works well on it’s own:
(example URL) https://fmesvc.my_org.ca/fmeserver/apps/my_process
When clicking on the link, the app appears in my browser with the default parameters filled in.
Let’s say, in this app I have a few published parameters that are required. (example) choice 1, choice 2, choice 3.
Question: Is there a way to set up my URL address to prepopulate those variables?
For example: https://fmesvc.my_org.ca/fmeserver/apps/my_process?choice_1=123&choice_2=456&choice_3=789
This way, when someone clicks the link, the app would appear in the browser tab with the parameters pre-populated?
This would be a great enhancement, as it would save users the hassle of entering in those parameters manually.
Thanks,
AB
LizAtSafe
Forum|alt.badge.img+15
  • January 10, 2025
Gathering InterestIn Development
LizAtSafe
  • April 5, 2025
LizAtSafe
  • April 5, 2025
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • June 13, 2025
In DevelopmentGathering Interest
