Archived
NLS_LENGTH_SEMANTICS parameter in Oracle Writer
Related products:Integrations
  • February 16, 2018
  • 61 views
geobroetchen
Forum|alt.badge.img+19
For now the Oracle Writer isn't capable of controlling the width between bytes and characters for varchar fields. The writer forwards the entered width to the database and the database uses the NLS_LENGTH_SEMANTICS settings to create a field either in byte or char length.
A writer parameter to "control" the width (NLS_LENGTH_SEMANTICS) would be a great improvement and if it's not a big deal this settings could be integrated into the Writer feature type.
Oracle it self recommends to set the NLS_LENGTH_SEMANTICS parameter to byte (see https://docs.oracle.com/cd/E24693_01/server.11203/e24448/initparams149.htm). If the user wants to use char he has to use a workaround with "SQL To Run Before Write" and "SQL To Run After Write".
LizAtSafe
Forum|alt.badge.img+25
  • April 5, 2025
Open→Archived
LizAtSafe
  • April 5, 2025
Thanks for submitting this idea. Our product management team has reviewed it, and it isn’t on our roadmap. Features in newer versions of FME may address this need; if not, please feel free to submit a new idea.
