Released
New "Workspace parameter" - Feature Caching - enable/disable per workspace
Related products:FME Form
  • April 24, 2018
  • 12 replies
  • 265 views
sigtill
Forum|alt.badge.img+25
I have some workspaces that are large and have too many lists/tables etc. These will not run with Feature Caching enabled - as they will use 20+ hours. Without it, its done in less than 1 hour.
Other workspaces I like to have Feature Caching enabled, and I easily forget to switch back.
Make a parameter - similar to Rejected Feature Handling - that is "per workspace". For instance:
Feature Caching: Enabled / disabled
erik_jan
Forum|alt.badge.img+26
  • April 24, 2018
I would suggest: If you run using batch deploy or using FME Server, turn off feature caching automatically.
Executing a partial run is not an option when using batch or FME Server anyway.
paalped
Forum|alt.badge.img+5
  • December 16, 2018
Or/And make the bool accessible from FME_MacroValues if featureCaching is enabled/true or disabled/false.
tomf
Forum|alt.badge.img+31
  • January 23, 2019
If turning Feature Caching on in one workspace that I currently developing did not affect any other workspace I have open or choose to open subsequently, that would be great. Often I'm running completed workspaces that need to run as fast as possible, to serve others, while continuing to develop another separate workspace.
sigtill
  • April 3, 2019
Extra issue when I work with 2 workspaces simultaneously. One of them I need to have feature caching on, the other one needs to have featurecaching off (testing parallell processing). They take some time to run so thats why I need to work on the smaller project the same time as the large one. Now I always have to remember to switch on/off featurecaching on the other workspace after I have started to run it.
  • July 22, 2019
Yeah, I pretty much stated the same problem: https://knowledge.safe.com/content/idea/68833/new-workspace-parameter-always-disable-featurecach.html
All run options should be associated with an individual workspace (local) and not impact the run of other workspaces (global). Especially if it results in a destructive operation.
fmelizard
Forum|alt.badge.img+22
  • July 24, 2019
This does happen.
nic_ran
Forum|alt.badge.img+20
  • January 27, 2021
RT @daleatsafe: yes, it does happen, but if you switch off caching in one Workbench instance, it gets switched off for all instances. It would be good if the toggle would only apply to the instance it's clicked in.
bobw
  • January 25, 2022
I started to create this exact request Jan 2022, but found this one languishing since 2018. This would be super useful and save a bunch of time when we realize that caching is on, have to stop the job, and start the run over again. Or, vice versa.
LizAtSafe
  • February 10, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • June 17, 2026
Open→In Development
LizAtSafe
  • June 17, 2026
In Development→Released
JennaKAtSafe
Forum|alt.badge.img+9
Hi ​@sigtill, happy to let you know this Workspace Parameter was added as part of the Data Caching re-haul we did for 2025.1.
You can now find this parameter under Workspace Parameters > Prompt and Preview > Enable Data Caching
