Released
Make the 'NoFeaturesTester' a Standard Transformer
Related products:FME Form
  • Sep 24, 2021 5:16 PM UTC
  • 17 replies
  • 621 views
mmccart
Forum|alt.badge.img+33
The 'NoFeaturesTester' custom transformer currently out on FME Hub is powerful. However, we're getting pushback from IT from using it in our production workspaces in FME Server. We've benchmarked their work-arounds, and it slows down the workspace significantly (2 seconds with NFT vs. 2.5 minutes with their suggested alternatives).
My idea: Harden this transformer and turn into a standard transformer.
Forum|alt.badge.img+63
Great idea, but I do have a workaround for your IT department:
A custom transformer is essentially a couple of FME transformers pretending they're a new one... so really it's nothing you couldn't have done yourself, but I'm assuming it's the "downloaded off the internet" that's triggering your IT people.
You can right-click it, see how it's made and then essentially recreate the whole thing yourself ¯\\_(?)_/¯
mmccart
  • Oct 5, 2021 4:30 PM UTC
Thanks @redgeographics for the suggestion. We had already tried that before I posted this idea. They shut us down on that work-around as well.
fmelizard
Forum|alt.badge.img+22
  • Oct 8, 2021 6:36 PM UTC
Couldn't resist giving this a try with the PythonCaller and a tiny bit of Python code (below).
My test workspace is at https://safe.my.salesforce.com/sfc/p/30000000ePES/a/4Q00000062X8/qxo57.8oLO_rAboNjMhtCPdEoJmLdAuLjB0KRXrSv4c
@mhab has in the past suggested we build in a set of "logic" type transformers like this -- NAND, NOR, EOR, OR, AND, etc -- that basically produce logic output (true/false) by either emitting or not emitting a feature based on the arrival (or not) of features into one or two input ports (depending on the primitive we're evaluating). Seems like we should do this.
In the short term, I trust you're allowed to use a simple PythonCaller...
Python code for the PythonCaller below:
import fme
import fmeobjects
class FeatureProcessor(object):
  def __init__(self):
    """Base constructor for class members."""
    self.noFeatures_ = True;
    pass
  def input(self, feature):
    If any feature comes in, we just delete it and set the flag to indicate that we did receive
    something. We don't output the feature -- it is just swallowed up.
    self.noFeatures_ = False;
  def close(self):
    If we never saw any input features, then we will output something. Otherwise, no output.
    if self.noFeatures_:
      newFeature = fmeobjects.FMEFeature()
      self.pyoutput(newFeature)
    pass
mmccart
  • Oct 11, 2021 12:38 PM UTC
Thanks @daleatsafe! I'll take a look.
Forum|alt.badge.img+54
  • Oct 13, 2021 2:12 PM UTC
I've used python in a similar way to @daleatsafe 's suggestion - details here as I can't post code or images as a comment https://community.safe.com/s/question/0D54Q000080hL1rSAE/is-there-a-way-to-log-an-error-when-no-features-in-input-file-or-when-feature-type-not-exists-
mmccart
  • Oct 14, 2021 5:14 PM UTC
Thanks @ebygomm, I'll take a look.
  • Apr 5, 2023 9:57 AM UTC
This is such an incredibly useful transformer, I'm surprised that it hasn't been promoted to a first order transformer yet!
  • Apr 5, 2023 10:02 AM UTC
Formatting for legibility :-)
import fme
import fmeobjects
  def __init__(self):
    we did receive something.
  def close(self):
LizAtSafe
Forum|alt.badge.img+26
  • Nov 26, 2025 9:42 PM UTC
Open→Gathering Interest
LizAtSafe
  • Feb 4, 2026 11:52 PM UTC
Gathering Interest→In Development
LizAtSafe
  • Jun 22, 2026 11:25 PM UTC
In Development→Released
I downloaded build 26333 just now and it’s not in there and it’s not available on the hub anymore. Does that mean it’s coming in a later build?
andreaatsafe
Forum|alt.badge.img+17
​@redgeographics - can you try the following steps:
  • search the Transformer Gallery for NoFeaturesTester in FME Workbench
  • Delete the definition of the transformer (should be possible by right clicking)
  • Then refresh the Transformer Gallery and you should be able to see the shipped NoFeaturesTester
That did the trick, thanks!
chriswilson
Forum|alt.badge.img+29
  • Jul 28, 2026 9:36 PM UTC
chriswilson
  • Jul 28, 2026 9:57 PM UTC
I should add that is 100% not a sarcastic GIF, I just never thought I’d see the day this happened - I’m delighted!
andreaatsafe
Quick follow up here, we fixed the issue in FME 2026.2.1 where it was not showing up as a shipped transformer if you already had the custom transformer installed.
All should be working well now!
