Released
GeometryValidator
Related products:Transformers
  • Jan 27, 2015 6:48 PM UTC
  • 23 replies
  • 494 views
fmelizard
Forum|alt.badge.img+22
Add more validation types and/or improve repair & diagnostics (tell us in the comments what you'd like)
fmelizard
Would like to be able to validate features the way Esri does
sigtill
Forum|alt.badge.img+25
  • Jan 27, 2015 7:03 PM UTC
ESRIValidator would be nice - to be sure that everything can be loaded. Instead of trying to send them through ArcObjects-writer and then getting the message on each error.
lars_de_vries
Forum|alt.badge.img+10
@sigbjrnherstad I think this counts for all writers. It would be nice to have verified whether you can write your data without having your model crashed.
Forum|alt.badge.img+5
  • Nov 13, 2015 12:06 PM UTC
More control over intersections would be good. Different packages seem to cope with intersedctions in different ways, SQL server spatial, ESRI, mapinfo all have their own rules on geometry validation. Be good to asign these rules in the validtor.
roland.martin
Forum|alt.badge.img+11
I'm always thrown by the fact that some features seem to come out of the invalid and repaired port, and others only come through invalid. I see the logic, but maybe it's worth adding a fourth port instead, so have valid/invalid/repaired/irreperable?
geosander
Forum|alt.badge.img+7
  • Nov 17, 2015 7:51 AM UTC
I would like more control over degenerate and/or corrupt geometries (especially 3D). Auto-repairing these makes things worse sometimes, so it would be great to have some influence on what to repair and what not.
Forum|alt.badge.img+54
  • Nov 17, 2015 10:46 AM UTC
Being able to validate geometry with a tolerance would be great
ksu_geographer
Participant
It would be nice if the Geometry Validator detected the same issues that ESRI's Check/Repair Geometry tools do. I can't seem to configure the Geometry Validator to get the same results as the ESRI tools no matter what parameters I change, especially when it comes to self intersecting polygons.
jpvo
  • Jun 9, 2016 3:07 PM UTC
A good documentation ascociated with sample data to test and understand the tool would be also usefull:
sample dataset for GV
.JP
mikkok
Participant
  • Participant
  • Feb 28, 2018 12:19 PM UTC
how about cad-to-gis validation: check if data has curves, compundcurves etc?
mikkok
Participant
  • Participant
revesz
  • Mar 1, 2018 3:10 PM UTC
Yes, an additional port for the remnants would be good. It is possible to filter the list of features coming from the invalid port but it is an extra step and usually want to know if the feature is repaired or failed.
  • Aug 20, 2018 12:33 PM UTC
Given the introduction of tolerance options to various other transformers it would be good to see it included in the GeometryValidator. Especially since transformers such as the snapper will already remove duplicate vertices with a tolerance it seems odd that you cannot do the same with the validator.
bruceharold
Forum|alt.badge.img+19
  • Sep 21, 2018 7:55 PM UTC
Perhaps within Data Interoperability extension, or with ArcGIS Pro installed, make shapefiles accessible as native Esri geometry and run arcpy.RepairGeometry per feature. This makes a repaired feature without attribution. In Pro there is an option for Esri or OGC validation.
with arcpy.da.SearchCursor('nz_localities','shape@') as cursor:
for row in cursor:
repair = arcpy.RepairGeometry_management(row[0],'KEEP_NULL','ESRI').getOutput(0)
repair
'C:\\\\Work\\\\Product_Management\\\\AIMS\\\\AIMS.gdb\\\\f70C0F16E_4FD0_4A02_932E_176E556'
  • Sep 24, 2018 7:47 AM UTC
I see actually, the tolerance options are already there, although I'm not sure exactly what the tolerance means for some tests.
LizAtSafe
Forum|alt.badge.img+26
  • Oct 15, 2024 10:08 PM UTC
Open→Gathering Interest
LizAtSafe
  • Feb 12, 2025 8:55 PM UTC
Gathering Interest→In Development
dannymatranga
The Esri Repair function in Pro always works better than the GeometryValidator, which is inconvenient because I want to stay in FME for all data processing. I often have to run Repair in Pro to fix a certain kind of polygon dataset I work with often after processing the data in FME Form.
mgg_beca
Forum|alt.badge.img+20
  • Jun 17, 2025 10:02 PM UTC
Hi there,
I just had the same issue. I converted some CAD polygons to a fgdb using FME form.  The polygons displayed fine in ArcGIS Pro, but when publishing to ArcGIS Online the output feature layer was empty. I tried the geometryvalidator in FME, but all features passed.  The Esri Geometry repair tool found 6 self intersections, and the features published correctly after they were fixed.
Thanks,
Marc
LizAtSafe
  • Jul 8, 2025 5:07 PM UTC
In Development→Released
andreaatsafe
Forum|alt.badge.img+17
I’m pleased to let you know we’ve made some improvements to the GeometryValidator in 2025.1.
The GeometryValidator now includes preconfigured validation presets for Esri, SQL Server, Oracle, and Snowflake. These presets check and fix geometry issues to match the rules of each format.
Additional updates include:
  • A new Spatial Standard Compliance rule unifies the OGC Compliant and OGC Simple checks, now with partial support for the extended ISO spatial standard.
  • The Self-Intersections in 2D rule is more robust and offers new configuration options for area boundary styles
phoeffler
Forum|alt.badge.img+13
  • Sep 1, 2026 10:42 PM UTC
I was having a difficult time trying to crosswalk the checks between the esri Check Geometry geoprocessing tool and the FME GeometryValidator, and was happy to learn about the option to select Esri Geodatabase as a predefined Set of Issues to Detect.
In my testing, the esri GP tool and the FME transformer each returned one error. Unfortunately, they are different errors on different features.
I’ll likely end up writing out all of the data to an intermediate file using a FeatureWriter, using a PythonCaller to get the required result from the esri tool, and use a FeatureReader, and then continue onward.
Any thoughts on a more efficient workflow or how to achieve parity between the applications is appreciated.
Running FME Form: FME(R) 2026.1.2.0 (20260512 - Build 26124 - WIN64)
andreaatsafe
​@phoeffler - glad you were able to try out the Esri Geodatabase preset!
We’d be interested in knowing which two different features came back with their specific errors. That would let us look into what’s causing the difference. Would you mind submitting a support ticket for this?
RE: workflow efficiency, if your ultimate goal is to have the exact same behaviour as Esri’s “Check Geometry” tool, then what you’ve described would be the way to go.
I’m going to close this idea since following up via a support ticket would be best or feel free to post a new question to the community.
