Archived
Function to Enable and Disable the Startup and Shutdown Python Script.
Related products:FME Form
rylanatsafe
siennaatsafe
fmelizard
nielsgerrits
+75
  • rylanatsafe
    rylanatsafe
  • siennaatsafe
    siennaatsafe
  • fmelizard
    fmelizard
  • david_r
  • nielsgerrits
    nielsgerrits
  • ebygomm
  • takashi
  • virtualcitymatt
    virtualcitymatt
  • danilo_fme
    danilo_fme
  • dustin
    dustin
  • jdh
    jdh
  • sigtill
    sigtill
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • vxn43
    vxn43
  • carmijo
    carmijo
  • tomf
    tomf
  • runneals
    runneals
  • bruceharold
    bruceharold
  • lorenrouth
    lorenrouth
  • jelle
    jelle
  • kennyo
    kennyo
  • chriswilson
    chriswilson
  • martinkoch
    martinkoch
  • jackyd
    jackyd
  • srg
    srg
  • ciarab
    ciarab
  • timboberoosky
    timboberoosky
  • courtney_m
    courtney_m
  • bibold
  • kimo
    kimo
  • gerhard
  • marko
  • larrybird
  • jleoncofgis
    jleoncofgis
  • nicohauri
    nicohauri
  • ml56067
    ml56067
  • nixynoodle
    nixynoodle
  • esietinga
    esietinga
  • andre.utilit
  • balthasar
  • moberdries
    moberdries
  • db_apha
    db_apha
  • ragjr
    ragjr
  • mbv
  • lencer
  • ecthelion
    ecthelion
  • samisnunu
    samisnunu
  • ekkischeffler
    ekkischeffler
  • mmccart
    mmccart
  • pflegpet
    pflegpet
  • johnt
    johnt
  • gabriel_hirsch
    gabriel_hirsch
  • bubblebeb
    bubblebeb
  • rchoucroun
    rchoucroun
  • asablomberg
    asablomberg
  • jneujens
    jneujens
  • giosp
    giosp
  • francis_m
    francis_m
  • geoal
    geoal
  • jpvo
    jpvo
  • wicki
    wicki
  • bertd
  • phoeffler
    phoeffler
  • soeren
    soeren
  • cbs
  • ccantu
    ccantu
  • mathieu_ambrosy
    mathieu_ambrosy
  • jerrodstutzman
  • spatial_k
  • helen.tait
    helen.tait
  • rhansen
  • samuelvaldez
  • brcalexm
  • msims
  • davidpark
  • markc
  • laurawatsafe
    laurawatsafe
  • tkaufmann
    tkaufmann
  • marshall.we
    marshall.we
fmelizard
A function to enable|disable the Startup|Shutdown Python Script at once would be desirable.It is always very expensive if you have to comment out all lines just jor testing
  • October 29, 2015
+1 to Mike's comment re python startup/shutdown scripts. We use python scripts to send emails, run other workspaces etc and it would be great to easily disable this while developing and testing
mathieu_ambrosy
Forum|alt.badge.img+4
Exactly one of my ideas too. Its very not productive to delete or comment scripts before launching the workspace.
Extent the idea to pre-SQL, post-SQL and TCL startup/shutdown...
Forum|alt.badge.img+5
  • November 27, 2015
Extent the Startup and the Shutdown scrypt in the main tab, the script will have a better visibility in the workbench for the user.
and delete the Output for each transformer !
gabriel_hirsch
Forum|alt.badge.img+12
This came up on a desktop basic course yesterday so I vote for this
runneals
Forum|alt.badge.img+22
  • September 19, 2019
Any momentum on this? @daleatsafe
rchoucroun
Forum|alt.badge.img+11
  • October 27, 2020
This really needs to be implemented. Particularly since feature caching has been introduced. If I run my script to a particular transformer, it runs my python startup and shutdown script. If I then run to the next transformer (using cached features) it runs my startup and shutdown scripts again. Some of these scripts are not trivial, the startup script deletes a geometric network, the shutdown script turns off versioning on the datasets, rebuilds the geometric network and turns versioning back on again. This doesn't need to occur every time I want to follow the outputs of each transformer. Please enable a switch to ignore startup/shutdown scripts when running a translation.
ecthelion
Forum|alt.badge.img+15
  • December 7, 2020
Can you just create a start.txt and/or stop.txt file and populate it with "Debug" when you want to do testing and set it to something else otherwise? Then at the top of you python you could do:
import fme, fmeobjects
f = open("start.txt", "r")
if (f.readline() == "Debug"):
  print("***** in Debug Mode, skipping normal startup *****")
else:
  print("****** Running usual startup *****")
# USUAL STARTUP ROUTINE HERE
virtualcitymatt
Forum|alt.badge.img+39
Is there a reason that this isn't a feature yet? It really would save a lot of time
  • November 10, 2021
Yes please , +1!
bubblebeb
  • November 22, 2021
Any update on this when it might become a feature?
arnold_bijlsma
Forum|alt.badge.img+14
One workaround in Python is to put triple double-quotes at the top ("""). This effectively converts the entire script into just a string, which Python does nothing with.
(PS: It doesn't really work if you use triple double-quotes within your script)
LizAtSafe
  • February 10, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • February 10, 2024
LizAtSafe
  • February 10, 2024
