Archived
Add toggle control enabling the startup/shutdown python scripting
Related products:FME Form
samisnunu
Add a check in the Navigator window under Scripting to allow Enable or Disable the Startup or Shutdown scripting to run.
During debugging, I frequently need to disable the workspace to run the Startup Python scripting. either I Cut and paste to Notepad, or I have to o comment out all script lines just for the sake of testing.
i can add a private parameter Type Choice "Debug" with values Yes/No, but I guess it'll be more handy if it is set by default in the Navigator window for any workspace.
rchoucroun
Forum|alt.badge.img+11
  • October 27, 2020
This really needs to be implemented. Particularly since feature caching has been introduced. If I run my script to a particular transformer, it runs my python startup and shutdown script. If I then run to the next transformer (using cached features) it runs my startup and shutdown scripts again. Some of these scripts are not trivial, the startup script deletes a geometric network, the shutdown script turns off versioning on the datasets, rebuilds the geometric network and turns versioning back on again. This doesn't need to occur every time I want to follow the outputs of each transformer. Please enable a switch to ignore startup/shutdown scripts when running a translation.
As @samisnunu suggested, it could be a toggle in the navigator window, or possibly, a pop up when executing along with the published parameters pop up.
ecthelion
Forum|alt.badge.img+15
  • December 7, 2020
Can you just create a start.txt and/or stop.txt file and populate it with "Debug" when you want to do testing and set it to something else otherwise? Then at the top of your python you could do:
import fme, fmeobjects
f = open("start.txt", "r")
if (f.readline() == "Debug"):
  print("***** in Debug Mode, skipping normal startup *****")
else:
  print("****** Running usual startup *****")
# USUAL STARTUP ROUTINE HERE
dustin
Forum|alt.badge.img+31
  • January 20, 2021
Another vote for a much needed functionality.
martinkoch
Forum|alt.badge.img+19
  • January 21, 2021
I only feel the situation already.... Who in the team deployed the workspace with the toggle still off???
Just like 'redirect to inspector'...
LizAtSafe
  • February 10, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
