Open
FME Flow recursion detection
Related products:FME Flow
  • Feb 20, 2025 8:41 AM UTC
  • 8 replies
  • 209 views
Forum|alt.badge.img+63
In our standard FME Flow training course we have one excercise where Workspace A does some checks on user parameters and if they are succesful it runs Workspace B through an FMEFlowJobSubmitter.
One of our trainees accidentally set up the FMEFlowJobSubmitter to run Workspace A instead and when he published it to Flow he made a recursive loop: every time Workspace A ran, it queued Workspace A again. I was busy helping somebody else at that time so when I got around to his question I noticed it had ran 17000+ jobs in a matter of minutes. These were low-impact jobs, so it wasn’t an immediate problem, but it’s safe to say that this has the potential of completely overwhelming an FME Flow setup.
After talking to Safe we decided to post it as an idea here to see if others have come across this as well or have opinions about it.
The big question would be:
Should FME be able to detect these recursion risks?
And in a broader sense: have you had this happen to you? Or something similar that you think FME should be able to detect and warn you about?
I recall one similar thing happening at a training course many years ago where a trainee had set up a schedule with a short interval (something like 5 seconds) to run 3 workspaces that each took 10 seconds to run. This was right before lunch and after lunch he was wondering why his machine was so sluggish. There were hundreds, if not thousands, of jobs in the queue.
Forum|alt.badge.img+54
  • Feb 20, 2025 9:05 AM UTC
The classic one for me is using a workspace runner without the child workspace having feature inspectors turned off. Only an immediate impact on me, frantically trying to close the pop up windows so I could go to the workspace to kill the parent job.
I think I’ve had that happen to me at least once too 😅
liamfez
Forum|alt.badge.img+44
  • Feb 20, 2025 6:43 PM UTC
I have also had that happen before with the inspectors.
I have not had this recursive loop happen to me yet thankfully. However I would agree that it would be a beneficial feature, maybe as a setting that is default on but could be turned off. Perhaps under the Advanced Run options for workspaces.
LizAtSafe
Forum|alt.badge.img+26
  • Apr 29, 2025 3:57 PM UTC
New→Open
helmoetz
Forum|alt.badge.img+18
  • Feb 2, 2026 9:57 AM UTC
As for the idea to be able for FME to detect this kind of recursivity, that could be pretty complex. What to think of triggering a notification that will trigger a workspace that triggers the same notification? In my opinion this type of mistake will usually happen in controled development situations, like an FME staging environment, as well as a production environment. Typically, this would hangup the development environment, and where this could be quite disappointing for people that develope or test FME workspaces, it will not hangup a production environment and therefore it will not have that much impact. Do you agree?
I never said it would be easy 😆
Yes, a good test environment would be able to catch these errors before they do any harm. But there’s times when people test in production (or set up the test environment differently).
And even then, I think it would be a good thing if FME could recognize these cases.
chriswilson
Forum|alt.badge.img+29
  • Feb 17, 2026 1:21 AM UTC
Perhaps where many small jobs are submitted, a notification to an admin email inbox or something else when a certain number of jobs are submitted to a queue in a certain space of time that is say 1000% of what is normal?
If it is large jobs - so the frequency of job submission would still be low but the jobs would continue endlessly - then something RAM or CPU usage-based could work.
Upon notification the admin could have an option to say this is ok or to clear all jobs in the queue, stop running processes or possibly restart Flow.  The latter may not work for fault-tolerant systems that would just flip the problem to the next server!
I’ve never face this issue so it’s off the top of my head.  One thing I’m thinking of is it’s not just recursive job submission but possibly also detecting DDOS attacks on rest endpoints/data virtualisation etc.
