Released
Esri Geodatabase SDE Reader: ARCHIVE WHERE CLAUSE documentation
Related products:Integrations
  • April 3, 2021
  • 85 views
mhab
Forum|alt.badge.img+10
In the docu for the Esri Geodatabase SDE Reader (ArcObjects) it says about the ARCHIVE WHERE CLAUSE:
ARCHIVE_WHERE
... One or both of the GDB_FROM_DATE or GDB_TO_DATE column names must be specified in order to form a valid where clause. If the GDB_FROM_DATE is not specified, the creation date of the archive will be assumed. If the GDB_TO_DATE is note specified, the current date will be assumed.
Suggestion:
It wouldn't hurt to add the detailed sytax to the docu, which is output to the FME Log only if you do something wrong in the WHERE CLAUSE:
i.e.:
The archive where clause must be in the format
'GDB_FROM_DATE|GDB_TO_DATE <logical operator> <date>
[AND GDB_FROM_DATE|GDB_TO_DATE <logical operator> <date>]*'
and be space delimited
Things like "(" or ")" which are standard in SQL are NOT allowed.
Michael
LizAtSafe
Forum|alt.badge.img+25
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/geodatabase/GEODATABASE_SDE_writer.htm
