Open
Enhancing Connectivity Between FME Form and FME Flow
Related products:FME Form
  • February 6, 2025
  • 97 views
laurentp
maddiel
jeannl
danilo_fme
+21
  • laurentp
    laurentp
  • maddiel
    maddiel
  • jeannl
    jeannl
  • redgeographics
  • danilo_fme
    danilo_fme
  • davtorgh
    davtorgh
  • j.botterill
    j.botterill
  • fgiron
    fgiron
  • larue
    larue
  • chriswilson
    chriswilson
  • matthieuv
    matthieuv
  • thdrg
    thdrg
  • revesz
    revesz
  • nordpil
    nordpil
  • carlm
    carlm
  • becchr
    becchr
  • cfvonner
    cfvonner
  • dannymatranga
    dannymatranga
  • jeand
    jeand
  • phoeffler
    phoeffler
  • sigher
    sigher
  • jfraver
    jfraver
  • arjan_heil
    arjan_heil
  • arenscott
    arenscott
  • mark2atsafe
    mark2atsafe
  • jlebrun24
    jlebrun24
thdrg
To strengthen the integration between FME Form and FME Flow, it would be beneficial to improve access to FME Flow's shared resources directly from FME Form.
Currently, we know that it is possible to access files stored in Shared Resources via a reader in "Select Files from the Web" mode, but it would be much more convenient if this capability were natively built into FME Form.
Proposed Enhancements
  1. Direct Navigation in FME Flow Resources (from FME Form)
    • Enable browsing Shared Resources or Network Resources directly from FME Form, without having to copy-paste paths or manually modify macros.
  2. Deployment parameters & Automatic Resolution of Macros and UNC Paths
    • Currently, if an FME Flow Network Resource (ex: $(SDEconnection)) points to a network drive, users must manually specify the UNC path in FME Form because the macro does not resolve automatically.
    • It would also be useful if Deployment Parameters could include connections to FME Flow resources (Shared Resources, Network Resources).
  3. Pre-population of FME Flow User Parameters in FME Form
    • When connected to an FME Flow instance, global parameters like FME_FLOW_WEB_URL could be automatically populated in FME Form.
  4. Access Alignment with FME Flow User Permissions
    • Access to files and resources from FME Form should respect the permissions defined in FME Flow, ensuring users only access the resources they are authorized to use.
LizAtSafe
Forum|alt.badge.img+15
  • April 7, 2025
NewOpen
