Open
Enable attributes-only reading from FGDBs/shapefiles
Related products:Integrations
  • Sep 15, 2025 8:11 AM UTC
  • 197 views
p_c_20
Forum|alt.badge.img+9
Often, I’m dealing with large amounts of spatial features, but only need the non-geometry attributes. Reading in a national dataset of small polygons must add a lot of time to the process. Reading it all in and then removing geometry is a small saving, but not much. Could we have a ‘no geoms’ option in Feature Reader/Reader?
PierreAtSafe
Forum|alt.badge.img+11
New→Open
bruceharold
Forum|alt.badge.img+20
  • Nov 13, 2025 5:05 PM UTC
For file geodatabase feature classes, you can create a view in the geodatabase, if you do not include the Shape column then the view will be a table without geometry.  This has the benefit of being always synchronized with the source feature class and requiring (almost) no storage.
PierreAtSafe
Hi @p_c_20,
I was advised the following for Shapefiles: reading only the .dbf file will only read attributes. To do this in FME, use the DBase Reader (.dbf) or drag & drop the .dbf file on the canvas. Since this file only contains the attributes, no geometry processing will happen. There may be some slight differences with schema types.
This coupled with Bruce’s advice should solve your problem I believe. Let me know if that’s not the case please.
I’ll close this idea once you can confirm that the suggestions above are working.
Cheers
p_c_20
  • Nov 20, 2025 8:50 AM UTC
Hi @p_c_20,
Cheers
Good idea. However, I am working entirely outside ArcGIS. I imagine I would need to go into that to create a view. It still feels to me like a modification to FME that has merit and saves time.
Appreciate the suggestions!
