Open
Easily override zip-file name on FMEServer Datadownload
Related products:FME Flow
ax_pflegpeter
rylanatsafe
cshepard
maddiel
siennaatsafe
+47
  • ax_pflegpeter
    ax_pflegpeter
  • rylanatsafe
    rylanatsafe
  • cshepard
    cshepard
  • maddiel
    maddiel
  • siennaatsafe
    siennaatsafe
  • ebygomm
  • redgeographics
  • takashi
  • virtualcitymatt
    virtualcitymatt
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • sigtill
    sigtill
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • tomf
    tomf
  • runneals
    runneals
  • james_c_452
    james_c_452
  • panda
    panda
  • arnovananrooij
    arnovananrooij
  • kennyo
    kennyo
  • chriswilson
    chriswilson
  • rag2000
  • simeon_h
    simeon_h
  • arnebrucksch
  • iangr
    iangr
  • digit42
    digit42
  • s.jager
    s.jager
  • zander
    zander
  • wizdatawizard
    wizdatawizard
  • annabayona
    annabayona
  • pierre_t
  • jenunn85
    jenunn85
  • tslack
  • dxirgu
    dxirgu
  • crutledge
    crutledge
  • becchr
    becchr
  • gavinpark
    gavinpark
  • jeroen
    jeroen
  • giosp
    giosp
  • wicki
    wicki
  • stevenjh
    stevenjh
  • brek_graham
  • jeand
    jeand
  • soeren
    soeren
  • geolucho
    geolucho
  • julien_m
    julien_m
  • mapsgirl
  • raghavendrans
    raghavendrans
  • jlebrun24
    jlebrun24
  • zoe.forbes
    zoe.forbes
  • olivig
    olivig
  • razu_ahmed
    razu_ahmed
sigtill
Default filename using the DataDownloadservice is : http://fmeserver/fmedatadownload/FME_2D764B0C_1515155526785_73956.zip
Create an FME_SERVER_PARAMETER on FME Desktop like : FME_SERVER_ZIPFILENAME that can override this name if not empty. Then you can easily create a complex output-file based on both published parameters and attributes created during the workspace. For instance in a workspace you have:
PUBLISHED PARAMETER
Startfilename = "3Dmodels"
attribute created within the workspace:
timestamp = "20180101"
FME_SERVER_ZIPFILENAME = "Startfilename + _ + timestamp"
Will give the filename:
http://fmeserver/fmedatadownload/3Dmodels_20180101.zip
and automatically this will be the downloadlink instead of the default:
  • January 6, 2018
Agree that the suggestion would be useful in some cases. I think it would be better if the resulting zip file path could contain not only timestamp but also Job ID, in order to make each file path completely unique. Since the same workspace could be run with multiple jobs at the same time.
virtualcitymatt
Forum|alt.badge.img+35
Still don't know why this isn't a feature. The UUID of the zip is a bit of a pain
  • September 27, 2022
Is this still not possible?
LizAtSafe
Forum|alt.badge.img+15
  • June 15, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
panda
Forum|alt.badge.img+18
  • March 28, 2025
Could use the name to include DateTime stamps!
rylanatsafe
Forum|alt.badge.img+13
