Archived
Distance calculation per pipe segment
  • September 30, 2021
  • 28 views
peteralstorp
Forum|alt.badge.img+8
Hi, fellow FME-lovers!
I have an interesting problem that you can help me solve in an efficient way.
I have many pipe segements as solids in an ifc-file, see example in Test2.ifc. The pipes are in 3D and can be connected in all directions. (I'm not sure about the fittings but for now don't mind them.). Now, I need to calculate length per segment and I started working no a complicated scripts (2D and algebra...) but there must be more of an FME-way. I'm thinking along the lines of creating a center line from pipe start to end...
If you have any ideas I will gladly listen.
Bonus: what if segments are bent? Will this be handled in you solution?
Peter
peteralstorp
  • October 1, 2021
I can see that I input this question in the wrong forum. I have also posted it as a question now. Feel free to remove from Ideas....
